337
If it will affect conductivityof the circuit if the adhesive gets on any of the component leads?
Hello, I was about to purchase some heat shrink tubing when I noticed they come in plain as well as a dual wall type that has an adhesive/glue layer. My question is whether anyone has found issues wit...
adhesive
component-leads
heat-shrink-tube
Oct 29,2020
Gorge
