308
Copper core PCB
Hello,For the PCB prototyping, can you do the copper core PCB with "direct thermal path", i.e., no dielectric layer under the thermal pads? If you can ,how the price is calculated? Thank you...
copper-core-pcb
Feb 14,2020
