Its simply voltage devider for esp32 to sense 18650 battery, n mosfet to reduce power consumption, im sitting all night tonigh on it . Is this schematic correct please
can I have a via in a pad
Change my E-mail address
How do you make something?
Request to use project
PCB+ assembly
are parts included by default for community projects?
Smallest via on flex circuits
Need engineer in or near Chicago, Illinois to create a PCB for a project.
Teensy 4.1 pin mount for kicad to start drawing the pcb.
can't open this Shared project
Lead Solder in Assembly
Steam&Amp DIY GT&BASS Preamp Parts list
Question about conformal coating
UL746 Conformal Coating?
Delete POST
will this board work with these cells?
Ross Feng
