254
Hello Is it possible to get 4 motors working independently
There are two l298n motor drivers, and is it possible to make 4 independent motors work properly, with equal power going to all 4 motors using these two l298n motor controllers? Thanks!
1298n-motor-controller
equal-power
4-independent-motors
Jul 18,2020
Li Zhuo
W37275CCSH52 Ruler
