533
pcbway declined (failed to review) gerber
there is a shared project GALAKSIJA PLUShttps://www.pcbway.com/project/shareproject/GALAKSIJA_PLUS.htmlpcbway declined (failed to review) gerber , but other pcb makers are accepting them wha...
failed-to-review
Jan 11,2020
LOTEC
