440
FLeX pcb construction
Hi, I am designing a flex pcb. I have some through hole parts which I want to install over stiffeners. Is it possible to have stiffeners drilled together with the flex pcb? Also is it possible to...
flex-pcb-constructions
Sep 20,2019
