327
Should the ground plane be placed under components to decrease EM radiation?
One question I saw:Should the ground plane be placed under components to decrease EM radiation, as (I think) this will increase the parasitic capacitance and limit the signal rate of the circuit?
parasitic-capacitance
EM-radiation
ground-plane
Oct 07,2020
Simon Taylor
