308
NTC thermistor and fixed resistor, which one has more advantanges?
Both NTC thermistor and fixed resistors can be used for limiting the inrush current. But which has more advantanges in this application?
limite-the-inrush-current
fixed-resistor
NTC-thermistor
Nov 11,2020
Dennis Farquhar
