419
How can I reposition a micro usb port in my project
The casing for my project needs the micro usb port to be in a different position, I'm thinking of using a micro usb extender cable to reposition it, are there any being methods for this? Thanks fo...
reposition
micro-usb-port
Jan 02,2021
Yiğit Atalan
