318
Look for the arduino controllable power supply
Hi all, I need to control the speed of a handful of small pumps independently. The speed is directly related to the voltage supplied. I can't really use pwm and the voltage to the pumps must...
no-pwm
converter
pump
arduino-controllable-power-supply
Dec 03,2020
Miguel Reis
