397
How do I read a data if all of the GPIOs are in output mode.
I'm trying to implement an LCD driver. All my pins have been initiated as GPIO output mode. My question is, how do I read a data if all of the GPIOs are in output mode? I mean, we can always chang...
LCD
output-mode
GPIO
Dec 18,2020
Pete Dudash
