460
can you make pcb from drawing (jpeg)
I would like to do a project with a PCB but have no time to learn how to make gerber files. i have a jpeg fire with the design layout. couuld you make a gerber file from it and make the printing for m...
pcb-from-jepg
Feb 19,2021
Benji
