349
Original Xbox capacitors.
It looks like all of these have a bulge on the top and obviously the reddish corrosion on top. I read up a little about this problem but I wanted a more professional view.
reddish-corrosion
capacitor
Aug 14,2020
Ardumani
W37275CCSH52 Ruler
