509
I wanted to know how to draw a schematic diagram of PCB
I was using express SGH application to draw the schematic but I put the components from the PCB but I couldn't connect them and now I am looking for either schematic diagram designer or a course I...
schematic-diagram-question
Jun 11,2022
Tim
