272
Is there a way to rename power labels?
I am trying to implement a schottky diode (BAT54C) that takes in +5V from the USB connection and +5V from an external source and joins them so that current does not leak backwards into the USB port. I...
schottky-diode
rename-power-labels
Aug 19,2020
Remy
W37275CCSH52 Ruler
