411
Is there a type of switch that only have the short press function?
I have a momentary swith wired to a board which has a short press and a long press function. I only need the short press function and I cannot program out the long press one, so I need a hardware solu...
short-press
switch
Nov 16,2020
Nicolas DEFRANOUX
I asked a quote to JLCCNC
Peter de Vroomen
gokul kb
