2821
square hole in PCB
Hi PCBWAY,I am desiging a newPCB.Question: is it possible to carve out a square 'hole' (instead of a round hole) in the PCB with size of about 1cm x 0,5cm?And is the PCB make process then '...
square-hole
Feb 18,2021
Nikola Krneta
