658
Rogers 4350B 4 layer stack-up options for 30 mil thickness
Hello,I wanted to know what are your Rogers 4350B 4 layer stack-up options for 30 mil thickness.Best Regards,Hossein
Stack-up
4-Layer
Rogers
Jun 05,2020
646
Stack up for 2 layers
Hi, this is Raul, can you guys give to me the standard stack up for 2 layers .8mm? standard material and dielectric constant?Tks in advance!
stack-up
Apr 02,2020
