824
Panelizing multidesign board
Hello,I have a multidesign PCB that I need to panelize. Can you please send me a PCB Panel with Tab route template?
Panel
tab-route
Feb 25,2022
PCBWay happy
865
What is your factory’s standard of panel by tab-route
Rep:For panel by tab-route, we required 2MM space between single PCB and the connection place need to wider than 1.6MM. As the stamp hole on connection place need to be 0.45MM diameter and 0.35MM spac...
tab-route
panel
Nov 20,2019
Mairaj Ali
I asked a quote to JLCCNC
Peter de Vroomen
gokul kb
