262
Do you have any recommendation? About designing a heat dissipation copper region.
What is your recommendation for designing a heat dissipation copper region with thermal vias for a 7805 regulator in D-Pak case? (9VDC input)
thermal-vias
heat-dissipation-copper-region
Jun 26,2020
Soen Drop
W37275CCSH52 Ruler
