7
895
Could I modify the soft touch switch to always on or bypass it?
I was planning on using a wifi socket to control this dehumidifier only to find out it's touch sensitive switch which defaults to off when plugged into power. Have you met this? Any way to bypass ...
touch-switch
WIFI
dehumidifier
Nov 05,2020
Gorge
