2746
If I have a design that needs V groove cut, what gerber file extension should they be in?
If I provide a design to PCBWay that will have rails that will be seperated after assembly with a V groove cut, what gerber file extension should be used and/or what note(s) should be added to the ord...
v-groove
May 22,2018
