424
Can anyone help me with the gerber file of Wifi router or Wifi Range extender?
I am a total freasher in this. I am looking a guy who can help me build a full router from the scratch. For a start i need a Gerber file of a Wifi Router PCB. I am willing to pay for it too. Thanks
Gerber-File
wifi-range-extender
Wifi-Router
Jun 11,2020
test test test
Change my E-mail address
How do you make something?
Request to use project
PCB+ assembly
Stephen Newport
