697
[PCB Prototype] Mechanical properties of Flexible PCB (or specific copper and polyimide which is used)
Hi, I ordered FPC from PCBWay which 0.15 mm thickness ( 1/3 oz copper, 2-layer min. track width 0.06mm)I will use this FPC in my senior project, but i need mechanical properties like density, you...
polyimide
poisson's-ratio
density
young's-modulus
flex
fpc
mechanical-properties
Mar 12,2021
Nikola Krneta
Is the "Adapter 2364 - 27128 (by Bobbel)" shard project still active?
How to download the gerber?
PCB cavity capability inquiry
Excellent work! This will be amazing in our observatory!
Bonjour Je souhaite commander le PCB Synthesizer UA7KJ Mega2560 V1.1 Il n'y a pas le Gerger pour commander .. est-ce possible ? Merci Marcel GIBELIN f1ge@sfr.fr
Hubcap Insert
I'm a beginner and I want to make a PCB with ESP32-C3 + MPU9250, can you help with the schematic?
capacitors question
Question about the dimension of the self-clinching standoffs for designing sheet metal project.
PS/2 mouse part not working
AMIGA 500 MEMBRANE
Conformal Coating Capability
does it have touchscreen function?
Product ordering
How would I order the assembled board from this project?
Ordering Panel
Which city is PCBWay located in? (for expensing purposes)
electrolytic capacitor question
In my application, the PCB needs to be partially submerged in water. Is there a PCB fabrication option or coating for preventing water ingress into the PCB layers if the PCB is submerged in water?
Flight-Simulator to use for SITL/HITL testing.
Hubcap Insert
capacitors question
AMIGA 500 MEMBRANE
Product ordering
Ordering Panel
Julian E
Aram Novikov
