632
[PCB Prototype]
about the 18650 pcb board
the last time l watched your video about the pcb catching fire or getting hot, l think the problem is because you placed the 18650 directly on the pcb board. when charging or discharging the pcb will ...
2019
03
22
Mar 25,2019
PCBWay Support Team
What is the length of data collected before/after the trigger for the Logic Analyzer LA104?
