AD20 Study Notes 3/3
Engineer asked Sep 29,2022
36. about power laying copper
Analog ground, power supply and digital ground, power supply is not the same, in the negative layer isolation. Double-click the isolation area to add a network.
37. Reduce interference
1. RJ45 interference suppression method: hollow all layers, P --> polygon rectangle hollow
2. Punch a hole for layer where the hole gnd is put
3. Stitching GND holes: THA, constrained area - raster 150mil - size 12.22 - select network GND- --forced oil cover--determined (provided copper is overlaid)
4. Bottom and top layer copper cladding
38. silkscreen adjustment
1. Select a silkscreen, right click - find similar objects - the first option to select the same OK - size 30.5mil
(6 times)
2. Select a component, only open the device selection, full selection of devices, AP adjust the location of the screen print
3. lower right corner of the paneis -- view can only select a layer to view.
4. View V can be flipped under the board
39. LOGO
1. LOGO into monochrome bitmap -- import -- convert -- paneis -- properties --select logo --change layer to topoverlay
2. Select all LOGO right-click - combine, select combine again and resize.
3. Add logo in the screen printing layer: screen printing layer add string - format to turn type.
40. DRC Check
TD - stop monitoring select larger - select rule - run
41. Organize information
Add comments to each layer, add measurements at the mechanical layer
1. gerber file output
FF-- gerber Files --generic inch ratio 2: 4 --draw layer select used- --mirror layer select all  removed --layer mechanical layer above all selected --select unconnected intermediate layer  pads --drill layer --- Select all
Large options -- Advanced -- xyz Add a 0 -- OK -- pameis -- CAMtastic
2. Drill files
FF -- NC Drill files -- OK
3. ipc netlist
FF-- test point report -- format select IPC -- OK the above 3 items can not be saved.
4. assembly drawing :
FM -- current document -- next -- pab print settings -- right click on the first large option --  Create Assmbly Drawings
5. bom table
Report the first option of R - select the output content - output format, template - export
6. Coordinate files.
FB - generates pick . --default--OK.
42. Single-layer display pcb:
Tap on the corresponding layer, shift+s
43. highlight network
CTRL + mouse click a line , the entire line of the NET network is highlighted
44. Change the alignment mode.
shift+spacebar
45. M+I
You can select all the components, flip over.
46. board inversion
v+b
  • Your Answer(0)
    1 PCBWay Team 5
    2 Engineer 2
    3 Engineer 1
    4 sheng wang 1
