Blind via diameter capability
blind-vias
vias
eagle
asked Oct 27,2018
Hello, I'm designing a 4-layer board in Eagle with blind vias from layers 1-2 and 15-16. I was wondering if the 0.2mm diameter minimum drill size for vias applies to blind vias as well as normal vias.
blind-vias
vias
eagle
