472
Have you planned to ...?
Hi. Your design is very clever and it touch my poor creativity. Looking at it, I see that it combine 2 different adapter in only one dongle. The three switches are neeeded to choose witch one will be ...
UART
ISP
Break-out
Adapters
Apr 26,2021
Pierluigi Vienna
test test test
Change my E-mail address
How do you make something?
Request to use project
PCB+ assembly
Stephen Newport
