964
[Others] Adding "Continuous current limiting" to a Buck converter with "Short Circuit Protection"
Hi, I have a beefy 12V 60A output buck converter which is advertised as having "Short Circuit Protection", I was wondering if I can use a current limiting circuit to essentially make this su...
Short-Circuit-Protection
Buck-converter
Continuous-current-limiting
Sep 29,2020
Bobby Iridium
