Crystal Clear GBC Flash Cart
Engineer asked Dec 03,2022
Hey!
I am interested in assembling the "MBC30 Flashcart | 4MB | FRAM | RTC | Crystal Clear Edition". This is my first time using pcbway so my question is if the Flash Cart is 100% completed and flashable if I order it. Or would I still need to add oem parts from a gbc cartridge afterwards.
thank you.
  • Your Answer(6)
  • 0
    According to the author's component list, we have sorted out a BOM, and now you can place the PCB+Assembly order. https://www.pcbway.com/project/shareproject/MBC30_Flashcart___4MB___FRAM___RTC___Crystal_Clear_Edition_1.html
    Engineer 2024-11-27 19:33:44Reply
    Are you able to provide MBC30 if assembly is selected? Thank you
    PCBWay Team 2024-11-28 09:48:10Reply
    The original author told us that MBC30 has to be harvested from an old game cartridge and cannot be purchased separately, so we provide this component, thanks.
    Engineer 2025-01-02 05:07:10Reply
    Sorry but your reply is ambiguous:
    do you provide MBC30 yes or no? Thank you
  • 0
    When you order it I believe you will just be receiving the bare PCB and you have to order and solder the components yourself using hot air and such. If you have never assembled a pcb before I wouldn't recommend this as a first project as it has some fine pitched components on it, but if you are up for a challenge go all in. As for oem parts from a gbc cartridge the only thing it look like you would need is the housing for a cartridge, which you can find and print 3d models from. If you don't have a 3d printer pcbway has 3d printing services you can use.
  • 1
    Its normally just the bare PCB and you will need to order the components and solder it yourself.
1 PCBWay Team 9
2 weslley ramos 1
3 Epishko Dmitry 1
