1596
[PCB Prototype] Bin file handling
Hello! Congratulations for the great job! :)Sorry for the simple question. I'd like to know how the bin files must be produced.Does the 1024k bin file need to be splitted or we need to use a diffe...
Electronic
Commodore
Bin-file
DIY-PCB
Oct 11,2019
