2673
[PCB Design] My ESP32-WROMM-32 doesnt enter into boot mode
Product: ESP32-WROOM-32.Application: Thermocirculator applied to the Sous Vide culinary technique.Controls: DC motor, heater, OLED display, cooler.Receives data from: Temperature sensor, water level s...
ESP-WROOM-32
ESP32-WROOM-32
ESP32
Dec 10,2022
Nikola Krneta
KhronoSound Audio
john James
LouD _
