960
[PCB Assembly] Glue Dot in mounting holes for connectors
Hello. I have a design that we're having trouble with in assembly; the connectors keep tilting over. I have a possible solution, but I need to ask a couple of questions. We have this connector wit...
Mounting-Holes
Glue-Dots
Glue-Curing
Glue-File
Feb 12,2020
Raushan Kumar
