I have a 4 layer board with internal power layers. I'm trying to add a decoupling cap to a DIP IC. The problem I 'believe' I have is that the 10 Pin is set to Vcc net and Altium is connecting it directly in the thru-hole. What I 'think' I want to do is add a via similar to the ground pin 11 to feed pin 10. Or am I misreading the entire situation and powering the pin from the Vcc layer provides the same outcome? And a follow up why doesn't the ground pad auto connect to the ground plane like the Vcc pad?
1 | PCBWay Team | 13 |
2 | Engineer | 1 |
3 | Engineer | 1 |
4 | Tim Keiper | 1 |
5 | Engineer | 1 |
