Is it possible? Multiple Outputs on 1 Pin?
Joson asked Jul 24,2020
Is there a way to connect 7 leds to only 1 pin on an arduino and be able to press 7 buttons which turn ON/OFF each of the 7 LEDs individually? I already know how to use an 1 analog pin for multiple inputs, but can you do the same with an output pin or is there another way?
  • 0
    No, you cant just connect 7 leds to one pin, if you want to control them individually, you probably should use shift register, you can read about most popular one, 74HC595, you'll achieve what you want
1 PCBWay Team 11
2 Engineer 1
3 Engineer 1
4 Franz Krenn 1
