Is this salvageable?
pcb
Solder-flaked-off
pin
Gorge
asked Aug 14,2020
Solder flaked off around a pin and took everything with it. That's the brown substrate underneath.
pcb
Solder-flaked-off
pin
Beans Awards Process
Why is my keyboard pcb so much?
Fraudulent authorship
Inquiry about Quotation Price
Pls help with changing the words on the pcb
3d Print Buying/Reviewing
How to layout a FPC in Eagle pcb
Account update
How does the IEC 61914 standard impact the manufacturing and use of cable cleats?
im looking for the creality k1 extruder replacement
Parts for SDK-85
Tube Tester
Do I need to specify bend radius in an order?
What is the minimum allowable spacing between 0402 chip parts?
Hi do you need to harvest MBC3/5 from an old cartridge for this flash cart to work?
PCB saved as PDF , how to upload?
Looking for board to use for my project,
24 led neopixel ring gerber file
I want to buy the PCBs for the 10kHz -255MHz signal generator designed by USTAOGLU AUDIO. Unfortunately I cannot understand your website ( too many options) Is there a quick simple way to order these
Account issue
