813
[PCB Prototype] development of board
Can you please tell me if you can order the development of boards for LEDs SMD 3030 and 2835, but I do not have Gerber files and I do not know how to do them. I can tell you the dimensions of the fini...
LED-board
design
development
Jan 15,2021
Вячеслав Моргачев
