411
[PCB Prototype] LM3886 composite power amplifier
Hello, it looks interesting! Would you let me see the specifications, measurements and the schematics?Also, witch is the price for 2 pcb?Thank you very much!
LM3886-composite-power-amplifier
Jun 27,2023
