795
[PCB Prototype] WEIGHT SCALE BASED ON ESP32
I am looking to design a weight cell PCB with Bluetooth using the ESP32 and HX711 connected to 50KG load cells.
LOAD-CELL
SCALE
WEIGHT
HX711
ESP32
Jan 02,2021
Yiğit Atalan
