311
[Others] What’s the best way to send a python file from the raspberry pi 3 to raspberry pi 0 for use by the pi 0
I'm looking to share a file from the pi 3 that contains a password to the pi zero that has the key to decrypt. I was thinking about using MQTT or SSH but am unsure of the file sharing aspect. Addi...
raspberry-pi-0
python-file
MQTT-or-SSH
Aug 18,2020
Remy
