761
[PCB Assembly] MXR Distortion Plus PCB code CIM?
Hi,I'm interested in this PCB but can't understand some code.What CIM stand for? Forgive me I'm a newbie.Is PCB powered by standard 9V negative center power supply?Best RegardsAlex
MXR-Distortion-Plus
CIM
diode
fuzz
PCB
Jan 30,2021
Alessandro Masci
