468
[Others] When using an NPN transistor for switching does the emitter have to be grounded?
I am trying to control a remote via the gpio pins on a raspberry pi. I don't want to have to use relays because of the space they take up and the mechanical noise. The problem is the pads of the r...
the-emitter
NPN-transistor
raspberry-pi
Aug 11,2020
Gorge
I am looking to have someone else design a circuit used for a raspberry pi 5.
Time to receive answer and manufacturing extra charges
Suggestion for 300 um pitch BGA
Pcb for Sputnik receiver
Item description and Bomb required, to get a batch made for a Retronaut Youtube video..
custom project
Will you recognize this custom component as a via?
PCB & Assembly Question
Mouse PCB question
Are there any price changes with the import policies/laws that have been started in the U.S?
Absolute position accuracy of SMT pads in one single side
Hole in pcb
missing components
Can I get photos?
Reparing control board for washing machine
Flexible Polyamide Heater in Vacuum Applications
Looking to have someone troubleshoot a circuit board that I designed using Eagle and produced the board with your company. Do you have such a service that might assist.
Hi, could you please tell me, which capacitator C1 on the D32 Joystick Adapter board is? Kind regards, Thomas
Categories for shared projects
Laser-drilled microvias 0.1mm
