1037
[PCB Design] How to use circuit board jumpers? - SparkFun jumper issue JUMPER_2_NC_TRACE_NO_SILK won't route under EAGLE 9.6.2
I asked this question over at the SparkFun forum and someone suggested I post is here because there may be more EAGLE users here.I'm using the SparkFun jumper library under EAGLE but having proble...
PCB-routing
jumpers
Jul 06,2023
Rebecca Afzal
