667
[PCB Prototype] Solder practice
Hi, I am practicing soldering. I would like something like https://www.pcbway.com/project/gifts_detail/RP2040_plus_Raspberry_Pi_Development_Board__dual_core_processor_.html So I can as...
Pcb-soldering-practice
Feb 28,2023
