768
[PCB Design] 14 Layaer PCB (88.5 mils Thick)
I would like to improve the PDN and would prefer to have Power/GND planes closer to TOP/BOT. Please help me in rearranging the S/P/G assignments to imrove: - PDN (with P/G closer &am...
Request--advice
Apr 25,2023
Christian Davies
