What a PCB Is Made Of
PCBWay happy asked May 11,2018
A basic PCB starts with a copper-clad fiberglass material or thin copper sheets adhered to either side of the board, as shown in Figure 1-5.
Figure 1-5. Core material.
With a multilayer board (a board with more than two copper layers), a piece of Pre-Preg (Figure 1-6) may be placed between these cores to create one solid board with several copper layers (Figure 1-7). Pre-Preg is made of material similar to the core with additional adhesive that will adhere it to the layer above and below.
Figure 1-6. Pre-Preg material.
Figure 1-7. Core material with Pre-Preg material creating a single board (one of two types).
To discuss the board materials and options to a manufacturer, the terminology should be understood. The following sections explain the materials and the items that make up the material.
Core/Core Material
Core material (see Figure 1-5) is a rigid sheet of fiberglass resin material that has two sheets of copper adhered to either side. Some material may have a copper sheet on only one side. The copper is measured in ounces (oz). The normal thickness, by ounce, is as follows:
? 1/2 oz
(.0007"[0.01778])
? 1 oz
(.0014"[0.03556])
? 2 oz
(.0028"[0.07112])
? 3 oz
(.0042"[0.10668])
PCB manufacturers will refer to the copper thickness in ounces, but during board lay-up, or when the materials are stacked together, the inch/mm thickness is used.
Pre-Preg
Pre-Preg material is made of similar material as the core material but is in a soft, pliable form and comes in standard-sized thin sheets. These sheets are stacked to create the following custom thickness (see Figure 1-6):
  • .002" [0.0508]
  • .003" [0.0762]
  • .004" [0.1016]
When thickness calculations are made, multiples of .002"[.0508] or combinations are recommended.
Copper Foil
Copper foil (Figure 1-8) is a thin sheet of copper that is placed on or between Pre-Preg materials and bonds to the Pre-Preg with the adhesive that is part of the Pre-Preg. These materials come in the following thickness:
Figure 1-8. Copper foil.
? 1/2 oz
(.0007"[0.01778])
? 1 oz
(.0014"[0.03556])
? 2 oz
(.0028"[0.07112])
Copper Plating
Copper plating is primarily used only on the finished board, on the external layers, and provides an additional thickness of copper to the board while plating the wall of the holes drilled in the board.
The hole wall plating is the main purpose for the copper plating but still must be added into the overall thickness of the board. The average thickness for the plating is .0014"[.0356], ranging from .0012 to .0014"[0.0304–0.0356].
Usually the external plating is added after the board is drilled and the external copper on the board is etched, leaving a thicker trace, as shown in Figures 1-9 and 1-10.
Figure 1-9. External plating.
Figure 1-10. Plating after etching.
Solder Flow
Solder flow is a process in which solder is applied to the external surfaces of the board on exposed copper areas (Figure 1-11). This helps prepare the board for soldering and protect the copper from oxidation. The copper areas on the entire board may be solder flowed, or a process called SMOBC (Solder Mask Over Bare Copper) will be used. SMOBC process is when the board is "masked" and only the exposed area (usually pads or areas that are to be soldered) will be coated with solder flow.
Figure 1-11. Solder flow.
Solder Mask
Solder mask (Figure 1-12) is a material that is used to coat the board to
  • Protect from surrounding environment.
  • Insulate the board electrically.
  • Protect against solder bridges.
  • Protect components mounted to the board.
  • Protect the board from heat generated from components mounted to the board.
Figure 1-12. Solder masking.
Some standards do not view solder mask as an adequate insulator because of the inconsistency between board houses in types and inconsistent thickness after application.
The Trace
A trace on/in a PCB is relative to a wire. It provides the same function of transferring electricity from one point to another while the strength of the PCB provides a rigid material to place components on.
The copper layers, as explained later, will each go through an etch process that removes unneeded portions of the copper, leaving only those traces and pads required.
The defining characteristics of a trace are the trace width and height/thickness. These are the values that determine the amount of current that a trace can handle, similar to wire. The rule of thumb for trace width is .010"[.0254] per 1 Amp external (normally 1.5 oz or .0021"[.0533]) and .040"[.1016] per 1 Amp internally (for 1/2 oz of copper). This is only a guideline. The actual formula is much more complex because it does not follow a standard multiplier. The values mentioned will guide the work but do not consider temperature and copper thickness. (The accompanying software includes a calculator that takes in all values to consider.)
  • Temperature (increase above room temperature)
  • Current
  • Trace width
  • Internal/external layer
Note
Formulas are necessary, but without a proper utility they are difficult to use and time consuming, which is why the accompanying software supports most formulas given in this book.
The Pad
A pad may consist of several different shapes and styles. Normally two types of pads are used, commonly referred to as a soldered surface-mount pad or a soldered thru-hole pad (Figure 1-13).
Figure 1-13. Lead soldered into a board.
A surface mount pad is nothing more than a square or rectangular copper area that is used for mounting surface-mount components. The size and shape depend on the component that is mounted/soldered to the pad. Most component manufacturers have recommended pad sizes for their components.
A soldered pad may consist of a plated thru-hole pad (PLTH) or a nonplated thru-hole pad (NPTH). Both are nothing more than a round, square, or oblong pad with a hole through the pad. This allows a leaded component to be mounted to the board by placing the lead through the hole and the lead soldered to the pad area.
The Plated Hole
The plated hole, shown in Figure 1-14, consists of a pad in almost any shape with a hole through the pad. The walls of the hole are surfaced or plated with copper and, in some cases, solder or some other protective plating. The plating in the hole extends from the external area and flows into the hole, "plating" the hole wall.
Figure 1-14. Plated hole cross section.
A plated hole wall is superior for several reasons:
  • Support of the external pad, allowing a smaller pad
  • Dissipation of heat during soldering, allowing a smaller pad
  • Connection from the top to the bottom layer regardless of component insertion
  • Support solder flow from the top to the bottom, eliminating soldering from both sides
  • Necessary for multilayer board for internal pad connection
The Non-Plated Thru-Hole
The non-plated thru-hole (NPTH) is nothing more than a pad with no plating in the hole. The pad is commonly used for single-sided boards or holes that have screw/mounting hardware. Figure 1-15 shows an unplated hole with no clearance on the inner copper layers. Unplated holes will commonly have an area around the hole clear of any copper (similar to the board edge) to prevent shorting between any objects that may be placed through the hole to any of the copper layers. If a board has no plated holes, it does not require the plating process. This reduces the overall cost (but in turn increases pad size), reduces available surface area, and doesn't allow internal layers.
Figure 1-15. Non-plated hole cross section (no copper clearance).
Slots and Cutouts
Slots and cutouts are similar to plated/non-plated thru-holes but are defined separately because of their shapes and characteristics. PLTH/NPTH are usually round holes but not always round pads, but the hole is drilled. A slot or cutout is cut into the board by a router bit and is an oval, oblong, or a rounded square shape. The "corner" of a slot or cutout is not square unless a special corner punch is used. Slots and cutouts are cut with a round bit; therefore the corner must be the radius of the bit, or larger. The router bit size depends on board thickness and manufacturer's capabilities. A small bit may be used on a thick board but must cut slowly to prevent breakage, increasing time and cost.
The Board Edge
The board edge deserves its own definition and attributes, due to the values that define the board edge. The board edge is any part of the board that exposes the cross section of the board, including slots, cutouts, and the outer edge of the board.
  • Your Answer(2)
  • 0
    PCBs are generally made from FR4 fiberglass or aluminium.
  • 1
    PCB is generally made from four layers of material which are bonded together by heat, pressure and other methods. Four layers of a PCB are made of the substrate, copper, solder mask, and silkscreen. The substrate is generally made of fiberglass which is also known as FR4. FR refers to fire retardant and provides the foundation of the PCB. The substrate layer is the thickest layer in any PCB though you will find their thickness to vary. It is the layer that offers rigidity to the PCB. It can also be made from flexible materials which sometimes can be stretched, too. Recently many innovative materials are also being used to create the substrate some of which are even plant-based. Some other materials are also used for making the substrate such as epoxy or phenolics. The boards made from epoxy resin suffer from thermal sensitivity, and the lamination can fade of quickly in some instances. You can find these cost-effective boards easily in the market and recognize them by the smell they give off. The material also needs the components to be soldered to it.
1 PCBWay Team 9
2 weslley ramos 1
3 Epishko Dmitry 1
