Why can't see OK Cancel button in Allegro?
pcb-design
cancel-button
Allegro
Andrew
asked Jun 22,2020
Help me, i can't see OK Cancel button?
pcb-design
cancel-button
Allegro
KhronoSound Audio
john James
LouD _
