439
[Others] How to switch on a small load when a applied voltage is removed?
Hello guys, I need to turn on a small DC motor when a applied reference voltage is removed. Do you know a circuit diagram for this or any idea of doing this?
DC-motor
applied-voltage
small-load
Oct 27,2020
Paul H
