912
[PCB Assembly] Want to make my first project with you - including assembly service.
Hello.I've registered to this great site a long time ago.Didn't order nothing yet.Really want to make/see my first assembles PCB from you.I've seen shared projects that include PCB prototy...
share
projects
assembly-service
Jun 12,2019
