470
I want to order the Solar Bottle Cap, does a battery come with it? If not, can you suggest a battery that would work with it and I will buy it too...
battery
bottle-cap-solar
Jun 03,2022
Alex U
Change my E-mail address
How do you make something?
Request to use project
PCB+ assembly
Stephen Newport
